Gigabyte GeForce GTX 980 Ti Xtreme Gaming Waterforce Review
February 3, 2016 | 12:13
Tags: #all-in-one-cooler #best-gtx-980-ti #factory-overclock #gtx-980-ti #maxwell #waterforce
Companies: #gigabyte
Gigabyte GeForce GTX 980 Ti Xtreme Gaming Waterforce 6GB Overclocking Results
We started, as ever, by pushing the power and temperature limits to their maximum; 130 percent and 91°C in this instance.
With these settings, we were able to increase the core clock by 110MHz to 1,326MHz, giving us a rated boost clock of 1,427MHz and an actual, constant in-game clock speed of 1,540MHz, an absolutely massive result. Going by base clocks, this is a 9 percent increase over what Gigabyte sets the card to at the factory, and a huge 33 percent boost above the stock speed of 1,000MHz. Gigabyte's OC Guru II software is pretty clunky, but it does allow you to implement voltage offsets. However, even with these we couldn't make the card stable at any higher frequencies.
We were also able to add 1GHz to the effective memory clock, taking it to 8.2GHz, a 14 percent bump that gave the card a new total memory bandwidth of 393.6GB/sec.
Overclocking - Battlefield 4
3,840 x 2,160, 'Ultra' Settings, 0x MSAA
  • Gigabyte GeForce GTX 980 Ti Xtreme Gaming Waterforce 6GB (OC)
  • MSI GeForce GTX 980 Ti Lightning 6GB (OC)
  • AMD Radeon R9 Fury X 4GB
  • Nvidia GeForce GTX 980 Ti 6GB
    • 49
    • 72
    • 47
    • 69
    • 45
    • 65
    • 44
    • 64
    • 39
    • 49
    • 38
    • 55
20
30
40
50
60
70
80
Frames Per Second
  • Minimum
  • Average
Overclocking - Middle Earth: Shadow of Mordor
3,840 x 2,160, 'Very High' Settings
    • 56
    • 68
    • 54
    • 66
    • 50
    • 62
    • 49
    • 60
    • 43
    • 53
    • 43
    • 52
20
30
40
50
60
70
Frames Per Second
  • Minimum
  • Average
Overclocking - Unigine Valley 1.0
2,560 x 1,440, 'Ultra' Quality, 0x AA
    • 5068
    • 4915
    • 4691
    • 4616
    • 3963
    • 3283
2000
3000
4000
5000
Score (higher is better)
  • Score
Posted by Hustler - Wed Feb 03 2016 12:37
Given that the latest Tomb Raider and Tom Clancy The Division are pushing even the highest end Maxwell cards to their limits at 1440p, (Ti benchmarks show drops to less than 40fps at the highest settings) I can't help but think that a £600 investment in one at this stage in their life cycle is somewhat throwing money down the drain.
Less than 6mths away from the new gen Pascal, its not that long to wait and given that the top end Ti cards from Nvidia have been matched by the mid-high end card (970 equivalent) for the last two generations, its not unreasonable to expect you'll be able to buy this sort of performance for less than £400 in a short while as well as cooler running and using less power.
Posted by SchizoFrog - Wed Feb 03 2016 16:55
YAY! Another watercooled product with tubing that looks like it's from a cheap, plastic kid's cup.
Posted by maverik-sg1 - Wed Feb 03 2016 17:10
Pascal can't be that far away, I'd rather save my money and buy 'the next big thing', there's more than a good chance for 'close to' same performance for the price of a 970 at launch (£350ish).
Posted by Dogbert666 - Wed Feb 03 2016 17:37
maverik-sg1
One of the things that made the 970 so good was its sub-£300 launch price :D
null
